Nexus 7 File Explorer Help
Liam1
On the nexus 7, where are apps/games installed by the google play store located.
I have downloaded 'ES File Explorer' yet no luck finding where apps downloaded on the google play store are located?
I have searched all folders named 'downloaded'.
Please Help!
Thank You.
Welcome to Android Central! Apps that are downloaded and installed from Google Play are done so automatically by the system, with downloaded installer files located in the system cache partition, which is essentially invisible to the user (if you're not rooted). Installed app files are in system folders which you might be able to explore, but the directories are protected, so you won't be able to modify or manipulate them.
ElZed
