Nexus 7: Loose Micro-USB port!
TomsAndroid
521
Hi everyone, I have a problem with my Nexus 7. Over the last few weeks, the charging port has become loose/faulty. To get it to charge now, I have to apply a light bit of downwards pressure (when the face is up) to get it to charge. This is a pain because now when I charge, I have to put weight on the cable to connect it. Also, I think this is related, I'm having trouble connecting to my computer. Even when it shows it's charging, it won't connect as a USB device anymore and might come up with an error.
Does anyone else have these problems and do they have a fix?
BTW, I can feel a bit of play with my port but it doesn't look particularly bent or out of shape...
Sent from my Nexus 7 :-)
Re: Loose Micro-USB port!
I had that problem when I accidentally knocked the N7 down from my nightstand. I realized it wasn't the port but the cable itself when I used another USB cable. Hopefully it could be on the cable end and not the N7.
Sent from a tablet on a crappy OS, using an app that I purchased from an app store that appends this signature below my post to make me look superior in social status to everyone else.
Thanks for replying! I had thought that it might be the cable but it doesn't seem to wobble too much. Was yours loose?
I have the opposite problem..
I find my connector a tad hard to insert -N7 is quite new, bought it two weeks ago. Can't wait to have a charging dock, using the side pins, instead of the USB connector.
I did have that problem but it has worked it's way loose!
A charging dock would be great.
Yup ... same issue ...Had to wobble and/or use weight.
Have to replace port, but repair guy can't source parts yet:(!
Have you popped the rear cover and looked at it yet? Could just be a loose screw has let the connector work loose.
btw, in checking for loose screws, I like to try backing (unscrewing) the screw to see if it's loose, not tighten...
Also the pic is with the speaker module (3 screws) removed...
http://sphotos-a.xx.fbcdn.net/hphotos-prn1/535528_4684887412674_1970301251_n.jpg
Thanks for the help. Funnily enough, when I took it apart, the actual USB port didn't seem loose. This made me suspect the USB cable and when I tried my friends cable, it seemed to be normal. I'm confused though because my cable doesn't seem loose either.
I think I'll try a new charging cable. Do any of you know where to get one?
Tom :-)
Sent from my Nexus 7 using Tapatalk HD
The cable that came with my N7 32gig came apart at the device end. The part you grip slid right of the connector. I used some superglue to fix it.
I'm not happy, exactly, to see that other people are having the same issue - but I am glad to see a teardown link. We've tried every micro-usb charger in the house on our Nexus 7 since yesterday and nada.
I'm really confused because I tried a USB OTG and it works fine. I'm thinking that I might have to buy a dock now, just so I can charge via the Pogo pins :-(
It'd be great to get a dock - if any of the stores could keep them in stock. But I'm offended that I'd have to pay another $40 just to charge my device when it shouldn't be having this problem in the first place.
deevencoo5
