Nexus 7 Not Charging
Same thing happened to me..I charged it for 12 hours from 6 am to 6 p.m. ( 20 % left of battery supply when I put it to charge).When I turned it on tommorow the battery indicator said only 40 % left of battery.I charged with my charger with came with my nexus 7.But first time when I bought it,I am sure I turned it off,but something discharged the battery to 0 % over night.That day I did manage to charge it for 12 hours to 100 % and then used it for second time and then chariged it like I wrote here in this message.My nexus 7 is just a week old and this was my second time I charged it.
How did you manage to solve your problem?I am thinking about replacing device if it's possible...
I'm having the same charging issue with the stock charger, it's simply not charging or charging very little. The only way I can charge my device is with my Touchpad charger. This happened after the 4.2 update. I was having no charging issues prior to this.
the same thing is happened to me mine in getting on I got it the day after they were released. Sometimes it just won't charge or it charges very slowly I am using the stock changer I plugged it in last night a 10 hours later it has gone from 30 to 80 and I turned it off before I started charging having read somewhere that a battery monitoring program was causing problems. This has happened before its strange because it says its charging if you turn it on it shows its charging in AC mode which should not take more then an hour to charge
Jacobanayas
