- Jan 19, 2012
- 643
- 33
- 0
I'm definitely going Nexus now. I like the Google experience, as phone-ish as it may be. Nothing against the Gtab of coarse.
Sent from my SPH-D710 using Tapatalk 2
One thing to consider between the two of these devices is that the Galaxy Tab 2 7" can be bought for $250 even, no tax or shipping cost from Amazon.
The Nexus 7 cost me $228* for the 8Gb model and it would have cost me almost $282* for the 16Gb.
I'm still happy that I returned the Tab 2 and have a Nexus 7 on the way, but I figured I would throw out those extra costs since they do make a significant difference in the price.
* These numbers are dependent on your state sales tax.
Sadly USB-OTG will not support native storage initially. Other devices like keyboards and usb-2-ethernet will be. We will have to wait for dev communitiy or google to come out with an update for that.
If this thing sells well without it, don't count on google, count on devs to come up with it.
Hm, so I wouldn't be able to use flash drives+USB-microUSB connectors to get around the storage limitation? That's what I was hoping to do. (tablet newb)
Nope. Better to go 16GB. You will be waiting (hopefully not very long) until storage devices and flash drives are supported. The same with HD video out. There will be a solution for that, probably a wireless one, IMO but not immediately.
Once I was able to determine that you can in fact drag and drop between the Nexus and a PC, I made the decision to make the change.
The Nexus 7 seems too centric, like how Apple is with their iDevices. That turned me off along with the fact that there is no SD card slot of any kind, micro or otherwise, to expand it's use and value.
Here's an idea for storage... DropBox! Sure it's cloud based but you can get up to 50 gb if you pay for it. Also, I just got an HTC phone and opened a dropbox account on there, and by going through their "getting started" wizard, I was able to upgrade to 23 GB of storage for free. Granted, thats just a promotion for HTC phones on certain cell carriers, but it's at least worth looking into to see if you are elidgeable. I know I'll be linking my N7 to my dropbox account for sure!
That aside, you could also use network attached storage if I'm not mistaken. After all, most people are going to have their N7 attached to their wifi network anyway. Personally, I have a 1tb usb drive. Sure, I would be elated to hook that up directly to my N7, but I'm ok hooking it up to my PC and sharing over the network instead.And who knows, maybe I'll just replace that setup altogether with a single network enabled hard drive.
Of course, though, like other people are saying, the dev community will probably break this problem wide open. I'm sure someone somewhere is going to make some sort of hack that allows you to hook up a USB SD Card reader. But we won't see anything like that at least until the N7 ships. Remember people... first comes the hardware, and THEN comes the software.
Where did you try the Tab? If it was a store model I understand the lag XD
The main thing about this decision is I would like a tablet layout and not a phone UI, but if I had to I could go without.
I know you said no rooting. But google has the n7 at a weird dpi. Change it and you have tab mode. Need root thou..
