Nexus 7 wont load
Hi i have a Nexus 7 thats been rooted and rom put on it cant rember what one.
The problem is yesterday it started playing up running very slow so i turned it or to restart it now only loads up to the x logo.
I tried the fix where you plug it in and power off from the bootloader still no luck.
Checked the battery is connected in side as seen that can be a problem thats fine.
any help would be great
thanks
Hi, afcbob...
If you're looking to reflash the ROM you're currently having problems with, boot into your Custom Recovery (CWM or TWRP), and navigate to the /download folder. If you downloaded the ROM .zip flashable directly to the Nexus 7 using Chrome (or some other browser) chances are good you'll find it there.
If this fails, and you don't have a NANDROID backup to fall back on, then you'll probably have to FASTBOOT FLASH the Google Factory Stock ROM for your Nexus 7... available here - https://developers.google.com/android/nexus/images.
Rgrds,
Ged.
Andacar
