No Data Connection on CM 6.1.1
Did you install the Gapps addon? If using ROM manager you can select it to install after CM is flashed.
Or you can find the gapps.apk hanging around the net somewhere.
Yeah I got it now, I installed them form a website, looks to be running good now..PHEEW!
And I want to say thanks to everyone who helped me with this, you guys are the best and always there, best believe that I will be pressing your thanks button!!!!
:cool:
By the way since I got most of the pros on here... Does anyone know if you can change the Lockscreen Carrier font? Not the Font but like put my name or something else instead ( only on the lockscreen) I heard you could.
Are you serious? You werent aware that I was rooted?! And your considered an Android Guru? I mentioned that I am running Cyanogen 6.1.1.... you are telling me that you can run CM without root?! NO! C'Mon MAAANN!
Hey, I was just trying to help ok. If by chance I had miss the part about you being rooted I wouldn't have intervene. I was only going off of the fact that you weren't getting any data network on the device.
Fortunately, the problem seem to be fix - thanks to members with knowledge of rooted phone issues.
Have a nice day..
Yeah, there's a thread for this over on XDA.
Techview
