No radio after install of ROM PLEASE help!
hicksbb
11
I just rooted successfully, but after i rooted I flashed Bamf 2.1 to my phone. Once I went through the whole process I rebooted and the update took place, I love the look of the ROM but now i have no signal(i guess no radio). I tried to flash the MR2 radio through ROM manager but every time I get an abort message. I would just try to go back to my backup, however I believe the backup failed when I tried to do it, so I now don't have the old ROM to fall back on. PLEASE help me! I have no signal! I have tried everything that I know how too.
You don't flash the radio in recovery you do that in hboot, and as stated before rename it to PG05IMG.zip and place on your sd card.
Power off your phone then power on while holding volume down.
When it asks to upgrade, upgrade.
Make sure you delete or rename the radio file from the root of the SD card after you're finished setting up the radio as well. Otherwise, you will have issues.
clhjr
