No sound on incoming text messages...
baggyp
73
6
Seems like I had this issue on another Note but I don't remember the fix. I have no incoming alert notifications on text messages. I've gone through the menus and verified everything is turned on, reset the app, switched the sounds to make sure the file wasn't corrupt but nothing has worked.
Not sure if it something to do with the Smart switch or what... Any help would be appreciated!
Thanks!
Thanks!
Do you have a Bluetooth device hooked to it
Thanks!
What message app are you using.
I have multiple bluetooth devices connected but it doesn't seem to matter if bluetooth is on or off.
I'm using the stock messenger app.
I had the same issue as you I changed to Google messages and problem went away plus it has RCS
That what I ended up doing.. Would have liked to know whats causing it though..
tao17
