No sound or ringtone sound from speaker
ammobass
OK. Here is how I accidentally fixed this issue on my HTC One S: At teh same time, press the volume down button AND the power button briefly. This got my sound going again after a frustrating day. Good luck!!
I had the same problem. When I listen music the sound stop for a moment. that is was a little problem but some days ago my notification did not worked . I made factory reset . after some time the same problem( no sound ). I made a hard format and a factory reset. A day later the same problem. I flashed another Rom . The same problem. I tried a new Rom. this morning the sound had some lags to. I uninstalled a lot of apps, and nothing . After that I uninstalled Advanced Task Killer and boom !!! My sound run normal no crash , no end, no problem. I hope is ok ! . Now I just listen music to see if the problem is fixed . If something is happening I will post again , if not ( I hope ) this is the solution !!!
P.S. my phone is Htc one X international version
Oh my god this helped also on the Samsung Galaxy S 3!! Thank you very much! You saved my phone and the door where i almost wanted to smash it :D
Don't know if I should laugh or cry.
My son has the same problem on his HOX and while trying to download "soundabout" I noticed he had it installed...
So instead of installing or upgrading it, I simply removed this app you recommended and his speaker works perfectly fine now!!!
Well, thanks for mentioning this app in your post then ;-)
Oh, the irony. :P
On my HTC M8 there is sound from my speakers for about 2 seconds then it stops? I restart it and the same problem?
OK. Here is how I accidentally fixed this issue on my HTC One S: At the same time, press the volume down button AND the power button briefly. This got my sound going again after a frustrating day. Good luck!!
Worked for my HTC M9!!! It 'dropped' the volume to zero and when I turned it up... voila...sound.
Hey
I have tried everything said on this page but I still have no sound
What do I do????????
Thankyou
Thank you very much, You saved my day.
Hey guys I fixed it, You need to do is to Go to Settings>Sound & Notification>General(click on its settings) then press many times volume up and volume down buttons, and reboot your device.☺ This works in my YU Yunicorn 5530, I hope this will work in every device☺
is there any damage to your ringtone speakers? if you need to replace your speaker ringtone. or is it wrong for you to start the vote?
Ferdezscotts
