No sound.....
cubetop
238
44
I saw this in another topic and it has happened to me. I thought I would start a new topic to see if we can track or fix this "new" issue.
Randomly waking from sleep, the phone will stop making any noise at all. This has caused me to miss phone calls and emails. It also wouldn't let maps use the gps voice for direction.
If you power the phone off and back on, it starts working again. I have checked and made sure that the phone didn't somehow get put in silent. It just stops making any noise at all.
Phone is stock, not rooted. Running the ICS ota. No leak flashes or anything of the sort.
Discuss.
Sent from my DROID RAZR MAXX using Android Central.
Reactions: bill2crazy
I think I was part of the other discussion you're referring to. This is something I've noticed as well, but have found that rebooting isn't necessary to get the sound back. I just go to Settings->Sound->Phone ringtone, and just select a random ringtone to hear it play. This "wakes up" the sound.
I've reported this to Google as a bug. The more people who do it, the more likely they'll pay attention to it, so go here
Issues - android - Android - An Open Handset Alliance Project - Google Project Hosting
and either start a new thread or search for a similar thread to add to it.
Ditto today. Maybe it's just now sinking in. lol.
Hopefully the upcoming patch will fix it.
Thanks B. It was definitely you I remember seeing. I'll put a reply in a thread too. Thanks again!
I created an issue since I couldn't find one like it. Issue 34962
Saw several threads about this in the Motorola owners forum, but haven't experienced it myself yet (knocks on wood).
Sent from my DROID RAZR using Android Central Forums
Reactions: bradenfontaine
They apparently "declined" my issue and told me to contact Verizon support. Hrm. Well, maybe they didn't understand the problem so I explained it a little more. *shrug* It's so random. I can't force it to do it and usually don't realize it's happened until I missed phone calls and email alerts.
Verizon replaced my phone because of no sound. Whenever I had no sound if I pinched the top of the phone (as if you're taking a clothes pin and attaching it between the flash and speaker) the sound would come back but it would keep going away as if something was loose in there. It got the the point that I could pinch it to get sound then tap my phone on the palm of my hand and it would quit again.
Verizon put me on hold for awhile and when he came back he said he see's several returns/exchanges for the same issue in the logs he was looking at.
This has nothing to do with hardware, I'm certain. It was discovered and I have verified that if the sound stops, you can switch ringtones and all sound starts again. Thanks for the input though.
I have no sound on video, music and games(media). Ring tones, notifications seems to be fine. I noticed when I was using speakerphone today the volume seemed low even though I had it maxed out. I have tried changing ringtones and powering down. There was no change in the phone.:'(
Went back to bestbuy mobile today. They set me up with new phone, zagg and made sure everything got synced and backed up.
New phone has ICS installed already. Here's hoping that it was a bad install on the update.
I have this problem frequently too...
Maybe this has been addressed before, but after updating google maps, there is no turn by turn voice navigation. Really needed it for my destination. Got home, uninstalled updates, and bingo, got voice back. Bug in app. Or ics?
I think it's ICS. I've had that EXACT bug in maps but if someone would have called you, you wouldn't have gotten a ring tone either. Changing ringtones clears it for some odd reason. It's definitely a software glitch.
Having this problem too... Any word if there will be a fix?
Nothing I've heard of but considering there are rumors of an update late in August (don't hold your breath), I'm hoping it is addressed then as well as other bugs like Flash, etc.
Interestingly, I haven't noticed the problem for a while now. I can't pinpoint what might have corrected the issue, or if I've just been lucky so far. (Of course, it'll probably happen again as soon as I finish this post.)
Reactions: cubetop
Thank god for this thread, I've been having problems with no sounds for calls and primarily texts and GPS. Thought it was something I was doing. Here's hoping there's a fix soon.
sent from my DROID RAZR Maxx
mersy78
