Note 10 Android 10 Beta: Issues and First Impressions
Re: Note 10 Android 10 Beta is available.
So far no hiccups. Banking apps work, AA Works.
Haven't had time to mess with much, but I can say the new gestures are so much better!!
Nothing available here in Ireland but I'm not ready to be a Samsung test mule anyway, I'll wait for final version, sure there will be plenty of bugs in that too :-)
Is it just me, or does this beta update make the note feel even faster? My gosh! It's so fluid and smooth.
I think it's the new animations. They're a lot like iOS animations to be honest.
Mine changed by itself I don't know why. I'm on the road at the moment if there is a setting for that bar
Delete
Mine didn't change. How do you get it to show the Assistant stuff on the right? Mine says "Say Hey Google" and has the microphone.
Here you go.... Tap on the bar like around the G
Then the 3 dot at the bottom "more"
Then customize widget
Not sure I like the new way of showing open tabs in Smasung Internet. I may like it once I get used to it. Not a big deal b/c you can still use the old way. I really like the little haptics you get from turning virtual buttons on and off though. Nice little touch.
Still discovering new things. It will take some getting used too. Hard for me getting used to the new gestures because I'm also running an S10 plus on Android 9 so that's going to be interesting trying to remember which way to swipe.
The new gestures are pretty easy for me because it works more like iOS which I'm really used to.
They're not hard for me but since I'm using Android 9 and 10, I have to remember where I am.
I know the feeling. I use my Note and iPhone both daily. I'm always getting the wrong side to lock the screen, or trying to swipe back in the wrong place. Now that the gestures are more similar it's less of a headache. The biggest thing I do though is hit volume down on my iPhone thinking I'm locking the screen b/c that's where the lock button is on the Note.
noroldie
