Note 10 Android 10 Beta: Issues and First Impressions
Any issues with secure folder after beta?
I haven't had any issues with it, but I don't use it all that often. I just kind of opened it, reactivated biometric log in, and opened a few more times to check to see if everything I have stored was ok.
I was able to resist upgrading for 6 hours since I saw first post in the forum. Now with team beta. 🙂
Looks like note 10+ is ready for speed test with any phone out there after the update. 😁
Just got this downloaded last night ... So far it's good ... Anyone using Goodlock... bummer so far I can't use new gestures with Nova launcher ... And if using Onehanded +
Some of the apps in goodlock are not working on mine either. Where it should say installed, it says unplugged. Hopefully Samsung fixes these soon???
Gotcha .. thanks for confirmation. I'm running Nice Lock which is similar.. just downloaded Good and I will check around it later today ..
Anyone know how to access Google Tap (Google Assistant, but has "share screenshot" option) with gestures? it's the Google Assistant you see when you long press the home button. Previously on 9, I could get it by performing the "swipe up to home" gesture slowly. It doesn't seem to be working on beta. Remapping the bixby button doesn't bring up that variant of Google Assistant. I double checked that long pressing the home button still initiates it. But I prefer the button-less gestures for more screen real estate.
Yeah with new gestures no go on Nova launcher
Swipe in from edge of the phone
Swipe up from the lower corners .. sides to access ..
How long does approval take after registering? After I registered the app took me straight back to the main screen showing that I can register for the beta.
The banner should disappear once register, if it still shows to register then clear cache,data,force stop the members app and try again
Many people on the Samsung Community forums had success with rebooting when that happens then check for software update manually.
That's only bringing up recently used apps to scroll thru for me. I must be missing the sweet spot? Lol, not sure why this is a challenge
Try swiping in diagonally from the bottom edge. Like from the outer most bottom right corner toward the middle of the screen. Not sure if I'm explaining it well. That pulls up assistant for me.
Adekanmbi
