note 2 battery question
A bigger battery. Have you tried one? Any you suggest?
You can go up to around 3900mAh with batteries that are the same size as the Note II's stock 3100mAh battery; however, if you want to jump up to like 6500mAh or 9300mAh, then you'll need an oversized battery, and a whole new back cover to accommodate it.
Brands like RAV, ZeroLemon, Hyperion, QCell, Onite and others are all fine. Just look for them on Amazon, and you'll see a wide range of prices. Look, also, on Youtube for videos which both explain and review them.
I've read ZeroLemon is the one to get.
Indeed, you can say so:)
Comparing with other brands, it lasts more. In my case, it`s about 2h extra, during an intense cycle of use (wifi, video calls).
In addition you can test it for 180 days, to see if it`s what you need
I bought the extra battery and charger kit from best buy for $27. I'm a heavy user and I switch the batteries out regularly.
If it`s Zerolemon, that you bought, expect the best performance ever:) It can last even for five days, used at full throttle
Zerolemon for $27???? I'd like to see where that is?
Zerolemon is the way to go. I have one with the rugged case and love it. I usually get 2 1/2 to 3 days with over 9 hrs of screen time.
Nehasingh12
