T t2800m New member Dec 15, 2013 3 0 0 Mar 15, 2014 #1 Hiya, just wanting what free launchers you peeps are using and which do you feel is best for usability? Cheers all! Posted via Android Central App
K Kdubbn Active member Jan 20, 2013 25 0 0 Mar 15, 2014 #2 Buzz Launcher. Love it. Simple and fully customizeable. Posted via Android Central App
S StarkillerFIN Active member Nov 3, 2013 37 0 0 Mar 16, 2014 #3 Nova Launcher. You can change icon grids, icons, fonts, folders an so on, like all those basic things. That's enough for me. And I'm using the Prime version, which gives me the option to use gestures. Posted via Android Central App
A amcjavelinsst Member Dec 20, 2012 24 0 0 Mar 16, 2014 #4 Another Nova Prime here Everything is easy And I run a Black Background which I like too Cheers Sent from my GT-N7105T using AC Forums mobile app
N nlitenme Well-known member Jul 3, 2010 544 1 0 Mar 18, 2014 #5 Nova Prime here also. It's a good mix of customizability & usability. Prime is the paid version, but the free version doesn't leave much to be desired. Try some out & see which one you like the best.
J jdauria Well-known member Jun 11, 2011 174 2 0 Mar 21, 2014 #6 Nova Laucher as well, been using it for years
K KOOLWATER Active member Jun 26, 2013 30 0 0 Mar 24, 2014 #7 Yep...... Nova Prime also... Love it Posted via Android Central App
tube517 Well-known member Jun 28, 2010 2,618 221 63 Mar 25, 2014 #8 Kitkat Launcher for CM11 ROMs Touchwiz for 4.3/Ditto Note ROM Nova when I get bored
