Note 20/Note 20 Ultra accessories discussion.
I was going to pay for it with a promo code. I don't have WSD yet, but this is a great point. Thanks!
I'd use the promo code for something else if you plan on buying the WSD. You'll probably never use the UV light from them again. You're paying $64 for it so might as well repurpose that light! ??????
Got ya! It kind of looks like the Ringke case I have now but mine doesn't have Kickstand. I'm waiting for the Samsung branded one to come for me to see it in person before buying another case.
This Ringke one I got isn't bad and is minimal which is just the way I like it.
I like Ringke. They make some pretty slim cases. I used them back in the S6 days and then went naked for a few years. I started getting cases again with the N10+. Anyway, here is my actual photo of the case.
Right! They all seem very flimsy, offering no real screen protection. Hopefully the Otterbox Symmetry and the Speck Presidio will do better than VSR, Samsung "tough" case, and ESR. ������*♂️
Clear case perfection is so tricky, and I seem to find differences every year. Another one I want to try is the Case Mate, they do a tougher clear option for the N20U that caught my eye online.
I believe the sanitizing UV light is UVC and I don't know the spectrum of the WSD UV light. It could be UVA, UVB, or UVC.
Just got my first case for the Ultra. It's the Spigen Tough Armor gunmetal & black. Feels good in the hand, not bulky, probably more protective than most cases I'm used too. I generally have gone with slim, light cases but felt the Ultra might need a little more.
Seems like every case I try gets in the way of the edge panel handle. I can't find a thin enough one.
Also, it probably takes about 10 minutes to run the sanitizer and the WSD light only stays on for 60 sec. I don't see myself pressing the on button every minute for 10 minutes.
I did that when I applied my WSD, lol
Appreciate the response, but you can't make the handle wider, just longer.
The cases I've tried all cover the edge higher up than ones on Note 10+, for example. It's like they all increased the coverage of the curve screen.
It's like I can't reach the curve part of screen anymore. Or maybe my fingers have gotten fatter.
Then edge + in Good Lock app give you wider border for handle
I haven't had a chance to post but I finally got my 512GB SD Card from Amazon on Thursday and installed that and my Supcase UBPro case is FINALLY coming on Monday (I've been using a cheap case I ordered from Amazon that WAS in stock, just to get by) but it is slippery as heck and I hate it! Need my Ford Super Duty Case!!!
I'm pretty sure the WSD light is UVA, which would not be as effective as UVC in killing bacteria - so I don't think the earlier statement was correct that they both have the same effectiveness.
Since both of my Whitestone Dome Glass screen protectors came damaged (and not due to shipping - still waiting to hear back from WSD btw), I had to run to Best Buy to pick up the Glassfusion Antibacterial screen protector since that was the only N20U screen protector in stock anywhere. It's like a thicker TPU screen protector, definitely not glass, but I'm pleasantly surprised about how nice it is. I may not want to go back to WSD.
After reading the recent issues of cracked Dome Glass screen protectors in the box this was the first thing I checked when the pack was delivered to me.
Thankfully both WSD screen protectors are fine.
With the regular note 20 being a flat screen. Does this mean that screen protectors will have full adhesive or will it only be on the edges like the note 10 plus?
kitlis
