Mike Dee
Ambassador
- May 14, 2014
- 23,497
- 412
- 83
I think devices that do 120W have split batteries in them that charge simultaneously at like 60W or something. If I could get that fast of charging I'd get it. Just would replace the battery every year. It only costs like a hundred bucks to do so.120watt charging would kill the battery
So the 45w works ?It's in the settings....just search for charging or fast chargingView attachment 324338
Yes, mine says super fast charging when connected to the 45 W charger with the correct type of cable. I think they ommitted it in the advertising because when the note 10 came out with it , most of the aftermarkwt cables couldnt support it so they probably had a lot of complaints from userw using the wrong cables and just left it out of advertising to avoid that again. Who knows. Definitely faster on the 45 watt tho.So the 45w works ?
Thanks , I see the option to toggle on , but don't have a 45w chargerYes, mine says super fast charging when connected to the 45 W charger with the correct type of cable. I think they ommitted it in the advertising because when the note 10 came out with it , most of the aftermarkwt cables couldnt support it so they probably had a lot of complaints from userw using the wrong cables and just left it out of advertising to avoid that again. Who knows. Definitely faster on the 45 watt tho.
Anybody’s got a 45w to compare with 25w to see if it does work?
Same here. There's very little does differences between the 2. I wouldn't pay extra for itI have no complaints with 25w charging its very fast
Even 60W is too high depending on the battery size and it's not something I'd leave unattended from a safety perspective.I think devices that do 120W have split batteries in them that charge simultaneously at like 60W or something. If I could get that fast of charging I'd get it. Just would replace the battery every year. It only costs like a hundred bucks to do so.
All the recent chargers say super fastI have both but have not tried the 25W charger yet, but the 25W in the box does say Super Fast Charging as well on it, my phone is currently fully charged but I'll let it go down low and measure the Watts when charging next time on the 45W
When your phone charges to 100% from 0 in 20 min, it would be pretty easy to watch it, if you so chose. The safety of it doesn't worry me so I'd have no problem leaving it unattended, personally. They wouldn't sell it to the masses if it was a high risk because it would make them liable. I'm all about the bleeding edge though. I can understand people being fine with what's offered currently. I suspect Samsung would be pushing the limits of speed if it weren't for what happened with the Note 7. They'll likely always play it extra safe in that respect lol.Even 60W is too high depending on the battery size and it's not something I'd leave unattended from a safety perspective.
Yes they do. My response was to a post discussing the charging brick saying Super Fast charging. The last couple of releases, the bricks all say Super Fast regardless of 25 or 45 watt.No they don't.
First pic, is using 45 Watt, checked via ampere. It is hitting 45 watts. Second is with 25 watt also verified with Ampere, it says fast charging on 25W. Note the slight time difference. View attachment 324511View attachment 324512
Gotcha, you mean the 25 Watt or the actual brick, the 45?My response was to a post discussing the charging brick. The last couple of releases the bricks all say super fast
