Note 20 Ultra fast charging
  • Start date Start date
Coming from the S20 ultra, I do notice slower charging on the note 20 ultra using the 25w adapter. On the S20 ultra is would take less time to charge with 25w charger, and it had a bigger battery. How can that be?
Here is what I got.... The in the box charger looks like it is the fastest by the tiniest of margins. That is from 55% maybe I will try and run it down lower and see if I can get a test from lower charge level.
First two are 45W charger
25W from the box.
25W from the box.
So that seems to suggest it does support it from what has been mentioned in this thread
I'll try and let mine run down to 2-3% and then stick it on the Samsung 45W charger with the Samsung cable and then time it, not very scientific but good enough as a reference point
I have the oem 45w and it says superfast charging as well. No idea if it actually means anything
Yes, mine says super fast charging when connected to the 45 W charger with the correct type of cable. I think they ommitted it in the advertising because when the note 10 came out with it , most of the aftermarkwt cables couldnt support it so they probably had a lot of complaints from userw using the wrong cables and just left it out of advertising to avoid that again. Who knows. Definitely faster on the 45 watt tho.
Mine says super fast charging when its plugged in to the stock 25w charger.
Can you explain to me what this setting menu is? When I plug in my charger, it "turns off" fast charging and super fast charging and only leaves fast wireless charging. Can you explain what's going on here? Thanks!
I just checked mine also which I dont when I charge it , says same must be error
The menu itself is to toggle the settings on or off
It leaves only fast wireless charging on , im wired charging
Yes...mine does that too. I'm guessing thats too prevent you from changing it while charging....why I have no idea. I'll check it on my other Sammy's but I'm guessing it's normal
ZackS
