Note 20 Ultra Shadow on White Screen ?
WOW, the nekkid screen is so sweet & crisp without the WSD ;) Plus the FPS works 110% PERFECT !
I just can't use the phone until I put something on it. Ordered some LK's to play with before I do WSD #2
Anyone else notice that these latest WSD glass panels are super thin compared to past generations?
Can't confirm the thickness but my spigen thin q case at the bottom is not fully in because Dome so I would say thickness is there .
I remember Whitestone having you press your thumb print down and hold it while curing the glass. Can't remember which phone it was but maybe it's something we should do with the Note 20 Ultra glass?
I think that was on the s10
Yeah give it a try
What's the chance my second WSD is going to pull the same deal? Maybe my screen is not flat?
I just looked at my WSD installs on my 9, 10+, and 20 Ultra - and I guess I do see some slight shadow on the edges, but it goes away if I move the angle I am looking at it just a tiny bit. It's most likely the glass causing it due to some refraction at the curve when you have two pieces of glass together. Have you taken a look at any of your other WSD installations on other phones? It literally goes away when look at it a few degrees off. That is, if that's what you're talking about. It really is barely noticeable for me and I thought I had OCD. lol
Anyway, your screen is certainly not flat, but curved at the edge. I am pretty sure you'll see the same thing by installing your second WSD. If it's the same thing that I'm seeing - I just assumed that was normal and it didn't affect my experience with the screen.
kankuraon
