Note 3: Action memo has stopped
Unacceptable.
If you, as Samsung, Android, or ATT, want to push me updates that I dont have an option to 'not install' you better make sure your updates don't kill my phone's functionality!
Am I supposed to waste my time to find fixes each time I get a required update? Don't you test you updates before you push them to consumers! Unbelievable!
This is the 3rd update, and no exceptions: again my phone does not work properly - i need action memo immediately and i figure out it does not work at all. This is too much. I'm already considering going back to Iphone, when they release Iphone6. At least it is robust. It does not have a pen -but well, the pen does not help me much after these updates anyway!
Well i don't know if it was just luck but i made it work...I open Action note WITHOUT the pen (with my finger) and it worked!!! After that it's working normaly with the pen. Try that and tell me if it works.
Samsung replaced Action Memo with S Note. Old notes are stored in device folder, actionmemo. Old notes can be read as jpg or deleted but not modified.
Hi. Action Memo is a very different kettle of fish to the Memo I had on my Galaxy S2. I had to find Color Note to replace memo on my Note 3.
S-Note did replace Memo yes. Action Memo saves or transcribes handwritten pen notes on a 'sticky' pad into different actions available when you circle your script. I never use it personally.
Re: Action memo has stopped
Actually, I booted the whole thing. Now it works. Hopefully that won't be a frequent necessity... But I'm happy to read tips on how to avoid such problems in the future.
How do you fix it?
i still dont know how to fix it
can you help me?
Sorry for my bad english
winarto
