Note 3 Battery drain...
Kc Anmol
10
I have note 3 N900...its just 10 days old....i updated from 4.4 to 5.0 lollipop.
I heard the note 3 has got awsum battery life but i dont think so....
I need to charge it at evening after full charge in morning...with wifi almost on the whole time
Average backup is of 9-10 hours with 20-30% battery remaining
I dont have heavy apps....
Yes my use is a lil heavy like watsap messngr chrome etc but atleast i shud get a backup of 15-20 hours
On 3200Mah battery....
CheckScreenshot_2015-05-03-13-18-29.jpg in screenshot...
It used 50% in just app. 4hrs....
Plz help
Well you have over 3 hours of screen on time so that seems pretty normal to me. You're on track for over 6 hours SOT. You can lower the brightness on your display and shut off any apps you don't use and sync apps less frequently, etc, if you want to save more battery, but you shouldn't expect 15 hours of screen on time no matter what you do.
Hmm actually the thing is...earlier i had grand2
And i used that phone too in the same amount....
I see no dffrnce betweek backups of both the phones....that has 2600mah
This has 3200mah....atleast there shud be a dffrnce
The Grand 2 has a smaller display, lower resolution, weaker processor, and I could go on. You should not be comparing these two phones for battery life. The Note 3 needs much more power, which is why it has a higher capacity battery. Btw, one of the joys of having a phone with a replaceable battery is not having to obsess over things like this. You're getting reasonable battery life and if you need more, just get a spare battery.
discoverwithmanoj
