Note 3: Why is my battery all of a sudden draining so fast?
Wanted to add that I have searched for a battery with extended life, but the only ones available also come with a case to adapt to the larger (much thicker) battery. You can't use the extended life batteries without a special (thick) case, which is very unfortunate, since I like the slim profile of the N3. Wah!
There is a lot of advice and threads on settings and what drains the battery needlessly. I think people have been aiming for at least 5 - 6 hours of screen on time, maybe a lot more. (touch Screen in Battery - also touch grey graph in Battery for signal use and other aspects during the charging cycle) I don't know what the longer battery times are. I currently have 21 hours @ 27% remaining (5 hours screen time), but I low charged in a car for 25 minutes. I learned recently that it's good for the battery to charge mid cycle, and bad to let it go too low very often (5-15%?). others may correct me.
*I edit a lot*
Anyone?
I had this issue. Someone in this forum suggested a wipe cache in recovery mode. That fixed everything for me.
*I edit a lot*
Anyone?
check my master post here, http://forums.androidcentral.com/go...ly-prolong-your-battery-life.html#post3222441
A very handy reference. I was told also a mid charge counts as a half cycle, and it runs cooler then, ref @rusty502 last week.
So, from your post link - avoid leaving it plugged in, when charged, if you definitely need 100% and may not be near a charger later; otherwise charge it to around 80% when you can and use 50%, but you have up to another 30% to use where necessary. The phones battery reading may not be accurate though. I'll keep those cycles as a reference.
It's more of a shame now, as I said then, that there are no chargers that give you the option to select when to stop charging. Although apparently my Note 3 controls the charge not the charger, so I'm still a little unclear there.
I am happy with my battery so far, though I had 2 GS2 batteries that degraded. I was trying to point the new poster in the right direction, very late at night.
Thanks.
There are several Apps for facebook with word Fast.
Which one are you usig?
Can you please give the developer name?
I also want to move from FB to a lighter version.
This also happened to me a few months ago and I don't know why
My samsung galaxy phone's battery life is all of a sudden draining quickly so the only device that I can use is my iPad Air, Help Please! :(
Do a calibration and post your results.
@T-Mobile GN3
Battery life shorten,phone is slow and gets very hot. This started 3 days ago or so but getting worse. Husband been complaining about battery life for about 3 weeks. I have deleted apps et . Phone just not working correctly. I have read that this is an issue with alotx
hackerbyron7
