Note 4: Font not supported
I want you to try this method because it worked on my note 4....search on Google or play store for an app called APTOIDE download and install.
Now in the search bar of aptoide type Flipfont Monotype and download those non trusted font... Example... Zapfchancery.. Install and apply... Good luck
The idea that only the newer phones are getting fonts is untrue. I have a sprint galaxy s7 Edge. Was having the same problem. I Solved the issue by reinstalling my CSC in odin. Turns out my CSC wasn't installed at all!
If you go to the google play store and search for fonts which have 'aeg' in the picture. I haven't been able to change my font since the update to Marshmallow and now I can by installing 'aeg' fonts.
Any questions, gimmi a shout :)
So, I'm trying to download some more fonts for my Verizon Note 4 (5.1.1.), and I keep getting this error. I've downloaded ifont and other programs but they all give me the same error. Anyone have a fix for this?
Thanks
Root your phone and use the app called "fontster" and thank me later
Aruz530
