Note 4 HRM LED comes on in pants
daytondroid
54
I updated my AT&T Note 4 to 5.0.1 yesterday with the AT&T OTA update and now the red LED for the HRM on my Note 4 comes on in my pocket. I have it positioned so the camera and HRM sensor face away from my leg and the screen is next to my leg. It seems the fabric of my pants causes the LED for the HRM to come on. I have never noticed this before Lollipop. It also comes on every time I put my finger on the HRM sensor as well.
Any thoughts on how to turn the HRM off or fix this issue? I never use the HRM on my Note 4.
Are you using Google Fit? If so, it's a known issue with Samsung's HRM and Google's app. Try uninstalling it or disabling it, it should fix your problem.
Thanks, that seems to have worked so far. I was not even using the app, but had it installed.
Yup, it's a nasty bug, unfortunately. I thought it was only for the GS5, but I guess the Note 4 is also affected :(
Somebody else posted that AT&T is aware and will have a fix in the next update.
Good Luck!
Ron
Unfortunately it seems it's not just AT&T, so Samsung has to be the one that fixes it.
dobebmo1
