Note 4 Is there really a gap in your phone?
Didn't even bother to check for the gap thing but did notice 2 small white lines and the small patches that corresponds with each small line on both top and bottom and one side.
Those are the antenna notches.
Sent from my 128 GB, Space Grey iPhone 6 Plus using Tapatalk
Haven't gotten my note 4, but I did notice the gaps on the demo units at best buy. Or I hope I'm referring to the right place. It's the gap from the edge of the phone to the glass screen right?
Yes.
I almost bought a N4 with a gap near the bottom left side. In checking for the gap, I used the edge of the protective plastic sheet that was on the screen and ran the thin plastic around the border of the screen. The gap area was obvious when the plastic slipped in between the glass and frame. The gap was easier to find this way than to see it, although I could see it once I found it with the plastic. Although I doubted that this gap was going to be a problem, I asked to see another phone that was perfect in this regard.
From visual inspection, no gap can be seen on my black Verizon Galaxy Note 4. However, if try to wedge a thin piece of material/paper, I can find a tiny gap near the bottom of the left bezel.
But I had gaps on my Galaxy Note 3 and Galaxy Note 2 as well. So I am not worried. In fact, the gap on my Note 3 was bigger.
I believe everyone note 4 had a "gap" which is really an expansion joint. It's there to ensure the structural integrity of the phone. At least that's what I think, I really have no idea.
No gap, but I tried sticking a crowbar in there to test and now I have a gap. Not really I don't have the phone yet :'(
Mine has mixed results:
Left side, no gap
Right side, gap big enough to insert business card
Top and bottom, gap big enough to insert paper
My Verizon note 4 charcoal has a noticeable gap on the left side and the top. Large enough for the tip of a steak knife.
Yes. I did the sticky note test and it fit. Not deeply, and not all the way around. I dont care. It doesn't detract from the look or functionality of the device so I'm good.
Mine has a gap for sure. Can't notice it when you have a case on it, but its there.
Mine does. And while trying to dislodge a large piece of dust, I scratched the inside near the glass. It's covered up now though.
via Note 4 on Verizon Wireless
Iknownothin
