Note 4 isnt recognized by pc and is charging very slowly
Mozilla214
7
phone is charging very slow even with quick charged mode turned on. but the thing is that my phone isnt displaying any quick charge notification nor displaying it in the battery settings
* Charging very slowly
* Charging only indicates USB Charging
* isnt recognized by pc
* tried reseting phone and updating & still nothing
* tried various chargers and USB
* also other batteries
Sounds like you have done some great troubleshooting. That being said, could very well be the port itself.
Fast charging requires that a lot of current ( like 2 A and
a lot of voltage too) be sent to the phone. USB 2 can only supply 500 mA, and USB 3 provides 900 mA and only the Note 3 and S5
even had that charging port. So the PC can only supply a Note 4 with 500 mA maximum. So no PC can supply a Note 4 with fast charge, PCs can't even supply current enough to be equivalent to a normal charger.
Did u use a different cable when changing chargers. I found out that my charge cables suck. I bought an anker and then my laptop could communicate w/the phone and charging worked much better. I'm only buying anker cables now, I used to buy various micro usb cables on sale, and most of the ended up not performing like the anker.
Do you have a tablet or another mobile device that you can test your chargers and cables with? Just to make sure that the chargers and cables are all working properly.
If they charge another device just fine, then I'd have to agree mhinc and would look at the port as the next possible culprit.
thank you i tried mostly everything possible and still nothing. i took it to a phone repair and they told me that it may needed to be updated or it may be the cord but after i tried everything above, im going to possibly replace the port and hope it gets fixed @mhinc
i understand what your saying, but on the pc part, the pc doesnt recognize the phone, like it will show its charging, but i cant open it and view any files or anything, it just doesnt show up on the pc. even when i set the phone to MTP mode, which is to transfer files @taife32
yes i used the original cable and charger, one for the s6, i even have a fast charge aukey kit, which makes any quick charge compatible phone charge at that fast rate, and those are good thick cables and various other chargers to make sure @fkchang
liquidsnake757
