Note 4 Screenshots! Show use those awesome home screens & more!
Re: Note 4 Screenshots! Show use those awesome home screens & more!
Cool clock, where did you get it?
It's a widget that I made using Zooper Widget Pro.
Wish I could make my transparent notification bar have black text. But oh well, I'll deal!
Are you using a launcher? If so look in the launcher settings, somewhere you might find show shadow on the top and bottom of the screen. I know Nova and Apex have that setting. It will darken the status bar and make reading it a little easier on light wallpapers. Doesn't give you the black font you want but it might help you out.
Omg thank you! I knew something like this was somewhere I just couldn't remember. Found it and it definitely helped! Thanks a bunch!
Question: How are you guys getting a transparent Google search widget? Mine is bright white.
Mine is ugly white, like this
If you use a Launcher like Nova you can change the look of the search bar or even eliminate it :
You can create it as a widget using Zooper. Or as mentioned if you are using a launcher you can use the persistent search bar option and select the that fits your need. Personally as a widget using zooper, I can place it anywhere and resize it to my liking.
If you check Andrew Daniel Gallagher G+ page, he has many Seahawks related icons and set ups you might get an idea from if you're into football...
Im looking for possibly a skyline background, Im not into sports whatsoever... I just cant find Icons to go with, I had that "Vinatge Seattle" theme I posted a bit back, but I couldnt see the icons at all in the sun. :(
carlo0213
