Note 4 Screenshots! Show use those awesome home screens & more!
Ok, going back to a launcher. Haven't used one in years. I'm using Nova.
I also decided this picture from a friend in Tel-Aviv that he took, would be a great wallpaper.
Changed it up!
Looks good. I wanted to reply to your earlier post asking about suggestions for icon packs for a Seattle themed wallpaper but didn't get a chance to until now. My original thought was that with Seattle being the birthplace of Grunge, you could go with a grunge themed icon pack (if you're into that). I have 2 different grunge packs that I've used in the past (my personal preference is the ruggy pack, which is the 2nd listed).
https://forums.androidcentral.com/e...s/details?id=com.vicino.grunge&token=IdRFTlGA
https://forums.androidcentral.com/e.../details?id=com.esethnet.ruggy&token=41vrluOe
To really get it to match up well with the wallpaper you are currently using, you may want to apply a grunge or vintage filter to the picture using just about any photo editing app that's out there.
If you prefer the look of your current wallpaper and don't want to alter it, try 3K SQR Glass.
https://forums.androidcentral.com/e...et.threekzerothree.icons.glass&token=xWbOxwRg
This is the icon pack I'm currently using. What I like about this pack is that the "frame" around the actual icon is about 95% transparent, which allows your wallpaper to be a little more visible and (imo) works really well with a "busy" wallpaper such as yours. Since I have a few minutes to kill, I googled the same Seattle image you have (I think it's the same) and added a couple of the glass icons to it so you could see for yourself.
However, since your wallpaper is B&W, I think this icon pack might look even better with it.
https://forums.androidcentral.com/e...eekzerothree.icons.glass.white&token=uydbbudz
https://forums.androidcentral.com/e...s/details?id=com.vicino.grunge&token=ZTlWvglR
https://forums.androidcentral.com/e.../details?id=com.esethnet.ruggy&token=Brvf-JXZ
https://forums.androidcentral.com/e...et.threekzerothree.icons.glass&token=qANh_R6Z
https://forums.androidcentral.com/e...eekzerothree.icons.glass.white&token=iJ1bMw8O
Can yypu share the image? I deleted mine. :(
Skywalkerbc22
