Note 4 Verizon difficulty connecting to 4G
dss2000
727
4
Since about December my Note 4 when set to global mode exclusively connects to 3G or 1x. Only way I can get it to connect to 4G LTE is put it in LTE / GSM / UMTS mode but then my reception gets spotty and many dead areas. If I put it in LTE / CDMA mode it stays on 3G similar to global. Anyone else have this problem and found a solution. I've cleared the cache and done a factory reset without any improvement.
You might contact your carrier and ask to have the connection reset. I just went through this a while ago and apparently the connection does need to get reset whenever this happens. Has been working fine for me since. I'm on VZW also.
Thanks, I called them and went through troubleshooting, they think it needs a replacement SIM card. They are sending it to me. We'll see if that works.
Good luck, I hope it works with the new sim.
liquidsnake757
