Note 5: Post Pictures Of Your Home Screen(s)
that's weird, I can see some of them but like 90% of them are all broken links.
Sent from my iPhone using Tapatalk
Okay, I tried those settings. But, then everything shifted over to the top left corner. I messed with the width and height padding, however, it's not making any difference. This is what is happening to mine.
Are you sure this is 6x6 layout? I just tried it out on my Note5 and the icons seem to be much closer together than yours here. In addition, I can then move icons to have the four in a row as reflected in gdgtmom's image.
Sent from my iPhone 6s Plus using Tapatalk
Example (Sorry for the lone icon, Kelly.)
Pretty sure you have to delete the apps to the very left and the ones along the very top to have your layout reflect your intended result...
Hey, yeah you're right. The result is staring me right in the eye, THANKS!
I GOT IT. Thanks Amy and gdgtmom.
How can you stand all the ads from Zedge? Why do they need to know my contacts? I was psyched to try it then read the reviews.
They just need to have access to the contacts app because Zedge is for Ringtones, Notifications, Icons, Wallpapers. Ringtones, notification to Set for your contact.
I see one ad about every third time I open it.
How else are they going to set ringtones and notifications, if you use that feature?
Ads are not bad, once in a while. The app is very good, love it.
Note 5 is DOPE
The ads sometimes play 30 second videos you cannot shut off. Do they also create ads in notification bar or homescreen or only when you open the app?
Lilrose
