Note 5 Tempered Glass Screen Protector, Same problem as Note 4?
felloffthetruck
Trusted Member
Mar 31, 2013
8,616
24
38
Does the Note 5 suffer the same curved screen problem as the Note 4, where tempered glass screen protectors will not work? :p
If you are referring to the halo effect then yes.
Sent from my Verizon Samsung Galaxy Note 5
No,, just had a Zagg put on,, NO halo at all. It's perfect, don't understand how anyone could just answer yes. Lol
Sent from my SM-N920P using Tapatalk
So far I've purchased two different tempered glass protectors and they work fine. The one Verizon sells is perfect when you get it perfectly centered. If you don't get it centered, you will have the halo (ask my wife). I also purchased two of the JETech tempered glass from Amazon just because they were cheap. They also work perfectly fine!
I am using Zagg and it's flawless
I'm using Zagg and it has the halo effect. Unsure if I should get it re-done after signing up with Zagg for their warranty.
It looks like it is but Best Buy did it for me while I was there. Could just be bad application on the part of the employee.
I find that the Zagg tempered glass screen protectors are completely worthless. The BodyGuardz tempered glass screen protectors are better.
I had sprint store guy apply mine,, his also has no halo
Does the BB Zagg use blue screen tech? This was an issue with the Zagg best buy sold for the s6, it would halo.
Best buy actually has their own version of the Zagg glass.
The ATT Zagg is flawless though.
Unsure it looks like normal. Here is a picture: EH0l1oc.jpg
Not really sure if I should get it re-done or if its pointless lol.
I'll have to look at the box of the AT&T version but I am near certain that is the best buy specific one with blue screen thing, notice in the top corner the sticker about UV protection.
Sent from my SAMSUNG-SM-N920A using Tapatalk
I went back to BB and they were like that's a common issue for note line phones but I should wait 48 hours. They said if its still happening after 48 hours I can bring it back and they will apply another one without any issues.
Best Buy were the ones that kept fouling up my edge protector. I'd take that back, and make them put a new one on it.
Wait 48? Lol they are just trying to get away from not replacing it. No halo is disappearing only some bubbles will vanish. With tempered glass if it's not on perfectly the first time it will never be.
ruhidubey017
