Note 7 runs hot
Sadly mine has a massive temp issue, just over 75c on boot up, then down to 38-40c on idle, doing benchmark testing it jumped to 82c (used CPU TEMP app) did same tests on my s7 edge it never got over 28c....spoke to Telstra and they are aware of the issue.. im to go to the Telstra shop tomm for testing and wait for samsung to send replacement out... just got this device tuesday
They are replacing all Notes that have been sold.
http://english.yonhapnews.co.kr/business/2016/09/02/22/0502000000AEN20160902009400320F.html
I use Ampere to monitor the temperature and voltage.
I notice when using the fast charger the temp has hit 105F. I have been setting my phone on an ice pack to keep the temps in the 85F range. I set rags between the phone and the ice pack to regulate the temperature otherwise the temp will drop very low.
I don't see a jump in temperature when charging via my laptop or 1A chargers.
At this time no one here can reassure you.... All note 7's are at risk for overheating and major battery failure... If my note 7 was acting that way I would head to a store to get a loaner asap..... I'm only holding on to mine until the new ones come back out because I don't have any so called symptoms
Noob
