Note 9 dual SIM on Verizon and AT&T, need some help.
cgr1971
111
14
18
I want to get a Note 9 dual SIM and run one SIM on Verizon and the other SIM on AT&T. What model is the correct one and will it be functional on both networks?
I am currently using a Oneplus 6T dual SIM and it has some reduced functionality, it won't do WIFI/HD calling on either network and is LTE only on Verizon. If I get a Note 9, will it at least have the same funcionality as my 6T?
I am hoping that someone has tried this before and was successful. I don't want to buy a Note 9 and try it only to find out it won't work.
Most phones that aren't carrier branded won't do WiFi calling or won't do it well. It's new technology, and will take them some time to get it squared away.
I'm ok without WIFI calling. The current capability of the 6T is fine, but there is a feature on the Note 9 that is not on the 6T that is very important to my business so I'm trying to find out if the Note 9 will at least work as well in the dul SIM configuration.
Most of the dual sim Samsung is international version which run on GSM like tmobile or Att, not sure it will work with Verizon Verizon CDMA
I have a VZ Note 9 and after spending time talking with Verizon managers and Tier Two techs, my Note 9 is not set up for dual sim on their network. The only phones that will work on Verizon are the iPhones, latest models and some of the later model Pixels. There might be others but VZ didn't confirm these to me.
The VZ Note is not dual SIM, the only phones that Verizon sells that are dual SIM are the iPhone 10's and 11's, and the Pixel 4/4XL's.
My question is if I buy an unlocked international dual SIM Note 9, will it work on Verizon and AT&T.
I was hoping someone had already tried this and knew if it was possible. I need to call Samsung and see if they can help.
