Note 9 features that you'd like to see
I would like
1. a larger battery
2. 2.5d screen (like in the Note 4)
3. a better camera that shows detail instead of beautifying/softening/smoothing out everything
4. a new and improved S Note or an improved Samsung notes which features/functions of the earlier S Note
5 Stereo speakers
6. 128 gb onboard ram
128 gb of ram?
I'd like to see:
  • a higher-capacity battery (couldn't care less about thinness)
  • keep it at 6 GB of RAM (I didn't think it would make a difference, but my S9+ with 6 GB is noticeably smoother in comparison to my regular S9 with 4) - I think 8 GB would be overkill unless it would make multitasking with DeX more useful
  • more internal storage options (64, 128, 256)
Throwing in a DeX dock or wireless charging pad would be a nice bonus.
S Note
S Note
and
S Note
Without having to go thru such shenanigans to sideload it, and not all features working.
And the death of Samsung Notes.
Me too. I like the Note feature but the main problem is that it doesn't connect me to other services. I have to export my Notes as PDF. Unless I use another program. Samsung makes a windows PC with pen support, but there is not Desktop app that syncs with the Galaxy Note.
Not having note syncing ability across different platforms and devices is a thing they need to fix. I don't want to export as a PDF all the time They'll probably just come out with a new 'feature' like writing gifs tho. We'll see.
S Note
S Note
and
S Note
Absolutely agree!. S Note was a big part of the Note line when it first came out.
I have a 400 gig card and that's great but I can't use it for apps. It's not fast enough and Android won't allow it without rooting which I have found next to impossible on this phone.
Settings>Developer Options>Scroll to bottom>Force move apps to SD card.
No need for root. You just need to unhide the Dev Options.
I'd like to be able to assign different LED colors without having to have a light manager.
I'd also like to see a messaging system that has the capabilities to send HD videos (similar to Apple) that doesn't rely on the MMS limitations and doesn't require another user to download and use that app to receive and send.
I'd like better speakers. My s8 plus speakers are horrid and I think they are going out.
Industrialbattery
