Note10+ I need a charge cable help me choose
elkido122
Active member
Oct 30, 2010
29
I need a nice charge cable to replace the stock one thays to short. Itll be used on the stock charge adapter . I see some that are usb c 2.0 and some that are usb c 3.1. Anyways can someone reccomend a good cable for this phone. Thanks
Anker [2-Pack] 3ft / 0.9m Nylon Braided Tangle-Free Micro USB Cable with Gold-Plated Connectors for Android, Samsung, HTC, Nokia, Sony and More (Red) https://www.amazon.com/dp/B07BRQSN5...ag=hawk-future-20&ascsubtag=UUacUvbUpU6638907
Bought these great replacement for stock cable. Great price and they are fabric covered cables
If you are wanting fast charging you won't get it with a 3rd party cable. At least that is my experience with Samsung
That's not true. I have found 2 different cable brands, one for 6ft and one for 10ft that both charge from the stock 25w charger at the same exact speed as the short stock cable that comes with it.
The 6ft one is sold out on amazon so I attached an image.
10ft is here: 60W/5.0A 10ft USB Type C to USB C Cable, CABEPOW 2Pack USB-C to USB-A 2in1 Fast Charger Cable Compatible for Samsung Galaxy Note 8 S8 S8+ S9, Google Pixel,Nexus 6P,Matebook, MacBook,iPad Pro Case 2018 https://www.amazon.com/dp/B07MBG677...ag=hawk-future-20&ascsubtag=UUacUvbUpU6639175
What about anker powerline or powerline 2 cables. Can they fast charge??
I got this one and it works fine with the OEM charger brick. Same charging time as the original cable. But it's not as long as the OEM cable. I think they do make a 6ft one though, and it should have a more flexible braided cable.
In any case, I started a thread about the proper cables to use, and in short, you want it to be USB-C on both ends, or a USB-C to USB 3.1 Gen2 connector to take advantage of the proper charging speeds.
slackingfred
