Note8 Pie on Verizon
I noticed that the first thing it asked me to do after the update was to check/update my emergency address. Not sure why because nothing has changed. Perhaps you should go to that setting and make sure it's current.
It was a persistent notification after the update. Until I force closed WiFi calling.
What's the version that Verizon is sending out? I'm still on the beta.
For some reason on my note 8 and my Huawei mate 20 pro both running Android 9 pie I can't post updates through the Android Central app
I can't quick reply but I am able to post with reply.
Checked yesterday at 12:20 and it was there.
Not sure if this is something new with Pie or if it's always been this way, but I just noticed that the app icon for the clock in the app drawer shows the current time.
How do I get rid of this ANNOYING 'Samsung Connect has stopped' error or something that has started since the Pie update?
I do love the update but this error is irritating and slows everything down.
Dex is a mess (worse than with Oreo). And it seems like Dex is an orphaned product, so I'm not counting on any fixes. Ughs. Great concept, failed implementation.
I had no luck with System UI Tuner. App refused to start, kept closing. Is this the only way to get rid of the clock on the top left side?
Ran fine on my Verizon Note 8. Did you enable USB Debug mode? I had to run some ADB commands from my laptop with the Note 8 connected also.
DannaOgle83
