Notice random battery drain
Like I said, you're garbage apps that are running constantly in the back ground. The ones that show at the top of your notification panel.
It is probably only one or two offending apps that is causing the phone to always be awake. He can use gsam to set which apps they are. Yeah removing the apps would get even better battery life, but removing the offending app would help a bit to begin with.
Sent from my Verizon Samsung Galaxy Note 4
sallysirl
