Notification when battery fully charged
Mattman86
79
Is there an app that can notify me when either my watch or phone is fully charged? This is a feature I miss from my Microsoft Band 2.
The charger for the S3 has a light that turns green. If you'll open your gear app and click on INFO, it will tell you if your watch is fully charged.
You don't need an app to tell you your phone is charged; you'd have to look past the lock screen that states "your phone is charged", to open an app that states "your phone is charged".
I usually leave my Gear or phone charging next to my bed while I go do whatever around the house. It was just really convenient with my Band 2 to not have to check for a light periodically.
If the app posted a notification to the watch and the phone, you wouldn't need to even unlock the phone or open an app to see the notification.
I had forgotten the Band 2 did that. I see where you're coming from.
if you have Samsung connect on your notification panel you can select it to open the app and it will give you your watch %.
tahirmehmoodkhokhar786
