ARCHIVED: [OC Kernel] Xionia Kernel 2.6.32.33 (v013)
Status
Not open for further replies.
Does VPN work on Optimus V? Please test both stock kernel and Xionia kernel.
Hey zefie. Do we need to get on the VC baseband before trying this new kernel? What exactly are the changes?
Thanks.
I mean, are these changes battery related? speed related? or just to fix something broken?
I lost my accelerometer when flashing 006. Also I am not sure if you know that boot animations freeze/shake when they reach their end, rather than loop and start over.
I think you are right. Also after flashing, the colors on my LCD seem way too overexposed. :confused:
I think my screen looks better :) But I want the screen to rotate.
I just tested it on my unfinished rom and auto rotate was disabled, checked it and it worked, so it cannot be the kernel, unless the new driver is incompatible with the old framework >.>
Unless you are on V
What do you need? I'm back to stock v9 and I can also confirm no rotate. Autorotate is checked.
Please redownload 006 and test the new boot.img updater. I cannot test it myself due to working on another thing seperately but it should work.
booting now. hopefully this doesn't screw up my dc-c
edit: yep killed dc-c. though all the FC's lol it doesn't appear to be flipping still. hopefully someone without the dc-c can test this better.
yeah your rom probably had a custom ramdisk which it wiped. but at least the zip works xD
Made a Nandroid backup earlier so just going to flash this really quick to test it :P
EDIT: First boot seemed to lock up on the Android boot screen, trying again really quick (this happens to me from time to time even before I installed this so could be a coincidence).
EDIT2: My storage space is down to nothing all of a sudden... like from 60 or so down to 3mb.
EDIT3: And it's under 2mb now and going down :( Gonna wipe and restore my backup before I hit 0. Going to try and pull a logcat off with ADB first, if I can though.
EDIT4: http://www.mediafire.com/?8nhh374h8yvl65p <- This is all I could pull off before my connection to the device reset for some reason.
For other reference, I'm running LegoROM with Deluxe Buildprops, v8 update.
EDIT4: log2.txt <- This is all I could pull off before my connection to the device reset for some reason.
try the new one i just posted, i am using a different initrd. also start from your nandroid restore, so that the broken /data is clean
Status
Annuji202
