Odd startup and progress bar this morning.
So maybe it wasn't the Google Play update if some of you had the same thing I did on startup yet are still on the November update? At least I know it wasn't just me and probably nothing to worry about.
Yeah, it looks like the Google Play update might just be coincidence.
I believe it's truly a Google play system update, but for some reason the version isn't being displayed correctly.
I got curious and checked on my 4XL, in the bottom left corner said to reboot, I did, it loaded something but the site still says 11/1/21 as it was before I rebooted. Weird....
My 3XL did the same thing today as well.... I also figured it was a Play System update, but I'm still on November 1st. That's the first time I've ever seen that particular type of update, with a percentage showing, on start up before though.
Saw this on my TMO P6P.. This was a couple days and reboots after I manually updated the Play System to December 1 via the system settings
I assumed it was probably a silent fix regarding all the zero click malware and less than honest apps that seem to be getting out of hand...
caritas
