[Official] CyanogenMod 7 discussion
The only side effect ive noticed from the fix is the bottom button lights don't illuminate. But if you change the brightness of the screen they come on. Weird. I believe the light issue is known now and it will be fixed in a nightly along with the mms.
I can deal with the bottom buttons. The one thing that is getting old is not seeing the mms that the wife sends. She can't remember to email them to me. lol
Anybody else had issues with the 4g antenna not staying or turning on? Every time I've installed an update, everything works perfectly. But after a couple of days, turning wimax on doesn't seem to stick. If I select it on, I get "turning on," followed seconds later by "off." Doesn't matter if I do it from wireless settings or the notification bar widget.
Just flashed #76 and the mms bug is gone. I was able to view all the pics that was sent.
Now my gps is off again when not on wifi. oh well that will get fixed as well. Probably when a final is released.
I'm still having an issue on by my phone and my wife's phone where the display stops refreshing. It's almost as though it's running out of display memory and having to swap it out or something. You open an app, or a settings window etc and nothing happens but if you scroll it starts showing up. I pretty much have to reboot to fix it.
It seems to happen every few days and it doesn't seem to be contributed to a single app. Is anyone else having any issue like this?
I know for developers bugs like this are a nightmare because they're not easy to recreate.
I'm running nightly #39 and my wife is running 7.0.3.1.
That has happen to me only with web pages and not apps, but its very rare. Usually I wipe cache and dalvik and that helps. Not sure if that really helps or just where it is rebooting but it clears it up.
I just couldnt let this thread fall to page two. It fell to the last one on page one....We need some new life in here, lol
Yes it has been slow on this thread but I'm sure it will blow back up when there is a 7.1 stable. Of course that could be awhile.
Does anyone else have the issue after flashing the GAPPS that gave google chat video that their camera only takes small resolution pictures? I tried flashing an older GAPPS but the problem persists. The version of gapps i flashed back to is 20110307 is there a different version i should flash somewhere?
Can't say I do. I did run into the problem of the video chat not working after updating to a new nightly. Then I couldn't get it to work even after restoring back. Had to wipe clean and start over for it to work.
Have you tried a full wipe and started fresh?
2 weeks, tops, before 7.1 stable.
How long have you guys been going since you last did a full wipe?
I havent wiped since nightly #0 and everything works fine. (Yeah i like to brag, so what ;) )
Biggest difference is 7.0.3.1 is 2.3.3 and #77 is 2.3.4. Also, GPS was good for me on the stable but the nightly (I'm on 76) is back how it use to be, off.
I tried the gapps for the stable that had video chat added but I always got FCs.
Battery life for me is running the same for both. Around 18hrs.
I'm on 76 and gps locks right on...did you do the gps fix where you use your msl # in a Sense backup?
koltyn
