[Official] CyanogenMod 7 discussion
do you guys know if would be possible to install the new miui camera app on the cm7 rom?
i try using root explorer and changing the permicios, but after the phone reboots i see the camera app on the app drow, but everytime i click on it the app FC with a message The appication camera (process com.miui.camera) has stopped unexpectedly. please try again.
can anybody help. i love CM7 but unfurtunally there is a big difference form the picutres taken with cm and a picture taken with the sense camera app, i was thinking about trying the new miui one to see if would help.
this is whow i had the permition setup
**0
*00
*00
Ok just flashed those radio ZIPs. Unfortunately no change in 3g speed. Still pretty bad.
Download: 0.62Mbps 0.21 Mbps
I need to remember to test 3g in some different locations.
WiFi blazes at full speed as it should luckily.
That stinks, I get 1.50mb to 2.24
Sent from my PC36100 using Tapatalk
Just bumping this to the top, and sharing that it looks there is a cool feature coming in the next nightly.. Slide toggle for brightness in the status bar :)
is anyone having really slow battery charge times?
is there anyway to change this?
There has been a few times I have noticed type of thing. Look in spare parts under battery info (I believe) & see if it says discharging. That was my problem for slow charging.
I haven't noticed anything out of the ordinary in regards to how long it takes to charge. I have however noticed that when it hits 90% charged my LED turns green.
That's normal for AOSP ROMs... You'll never get a full charge unless you install a non-SBC kernel for the trickle charge... but I don't recommend that at all.
Sent from my EVO 4G using 2 cans & a string
I hit 100% quite frequently on the CM7 stock kernel. However, the led does turn green at 90% as that is the intended behavior.
It should still immediately drop to 90% once it's taken off the charger... so it's never really 100%.
Nope. If you're seeing this behavior I'd say you might have an issue. My battery drains quickly but not /that/ quickly... ;)
Interesting... I was given incorrect information then...
What's up with the battery being so ridiculously bad on nightly 87? 3 minutes from having the screen on the battery drops 6 percent. When I unplugged the phone its in 100 and when I step outside like and check the battery is at 97% it drops 3 percent in less than a minute with the phones screen not being on the phone is just in my pocket. -___- wtf
I guess that's why they call it a nightly lol
Loki Samhain
