[Official] CyanogenMod 7 discussion
Does anyone know how to change the color of the pressed icons? I installed a theme that put an ugly color and i forgot where to change it. Running cm7 2.0.1
Sent from my PC36100 using Tapatalk
If you are referring when you tap on an icon and it has the orange color; then the settings to change that is in adw.
I been running nightly 81 for a couple of weeks now and so far no problems. Battery has be great on the stock kernel. If you don't know the nightly builds are based off of 2.3.4 and the stable is 2.3.3. Also, the nightly builds have a new gapps.
As with any new nightly there is a chance of bugs, but I been happy with #81
So is the nightly better than the stable release?
Better is a subjective term. I went back to 7.0.3.1 when MMS broke on the nightlies, for me, 2.3.4 wasn't worth risking a feature I need breaking and the time it would take to roll back to a previous version.
That bug has been fix, but yes I agree about it being subjective. It just comes down to the user.
92 only had one minor change on a format all error...otherwise it's the same build as 91.
is anyone using the updated radios from the new OTA update with CM7 yet? if so how did u flash it. I see in Rom Manager it says to downgrade to 2.507 to flash it.. Has anyone tried it and has it made any improvements?
I'm on the new radios and flashed them when I was on CM7. I haven't notice anything in my area but that doesn't mean you won't.
I use Amon_RA to flash it. To flash put it on the sd and install from sd. Flash it and it will do some things and the menu will pop up and it will say to reboot. Do so and then give like 7 mins and the menu will pop back up and reboot. That is it. Never pull the battery when updating the radios. That would be a good way to brick your phone.
Thanks I flashed it using Clockwork and it worked.. Don't see any difference yet tho
uh oh
hopefully after 223 pages there's still someone willing to help a noob out. i temp rooted using z4, downloaded titanium and backed up all my apps. I then rooted using the stickied method, so i was on the sprint lover's rom. i restored my apps using titanium backup and backed up my rom using rom manager. then, i downloaded cm7 and loaded it using rom manager. however, i didn't reset my system back to factory settings before doing so, and now i'm stuck on the cm7 boot screen (and removing the battery doesn't help, as is probably expected). so, am i screwed? can i re-load my sprint lover's rom? any help will be appreciated. thanks.
andiox
