[Official] CyanogenMod 7 discussion
So, Im rocking CM7 nightly #7 and it is great. Does anyone know if there is a build that has similar battery life as #7 or has anyone fixed the GPS problem on #7? Which build do you consider the better in terms of Battery life..no G4 in my area, so im not too worried about that. Thank.
Today I'm having issues with texts sending. Was on build #8 and decided to try flashing to a previous build that I was having no issues with. Back to #3 and texts still failing and outgoing calls not initiating for almost a minute. Anyway for me to tell if this is a Sprint problem today in my area vs a Rom/device issue? I did nothing with superuser permissions over night.
So it appears to be linked to Handcent (SMS app I use) and seems calls were not initializing due to ongoing attempt of device to send extended texts. So may be just Handcent fail today.
Since its 2.3.3 maybe koush needs to update Rom manager. Idk how that works since I've never used RM
One thing I am noticing on this CM7 is I don't seem to be getting a very good single I am in downtown Chicago where normally I am able to get a 4g signal. Now it seems as if it's barely getting a 3g signal right now it's showing 1x!
Hit an interesting bug today where my unlock screen (connect the dots) went crazy, and I had to do a battery pull to fix it.
i didn't get a chance to test CM7 build 11 hdmi, did anybody try to see if is working yet?
Why am I not seeing a build 11 mine stops at 8?
Mine is doing the same thing... I'm using rom manager and it's been on #8 for the past few days.. anyone have a solution? I would like it to work since I did pay for it.
Sent from my EVO 4G using Tapatalk Pro
I mentioned to Sasha that build 11 is updated to 2.3.3. Maybe RM needs to be updated or something. I don't know. Ask Koush.
Build#11 with 2.3.3 update Rocks!! Everything works just so much better, smoother and snappier. minor issues I had with previous builds seem to have fixed itself and this Rom feels just rock solid.
I found this link Android 2.3.3 Platform | Android Developers that details the new features of the 2.3.3 update and its extensive. Can anyone confirm whether the above link features are in the CM #11 2.3.3??
So #11 has 2.3.3 implemented into it now?
kankuraon
