[Official] CyanogenMod 7 discussion
i just tested on my and it works grate, i tested on windows XP, and windows 7.
however for some reason on my wifes laptop(win7) it takes several trys before i get data to work, but only on her leptop my is running win7 as well and it connects right way.
hope it helps
Not sure why it wasn't working, but I reflashed and it's working now.
Two questions.
1) How do I get rid of the Voicemail notification bug? It's always telling me I have 3 Voicemails. I tried changing the number from the *86 prompt to my number but it doesn't work. I don't want to use Google Voice either as my Voicemail.
2) I'm afraid in a hurry of rooting, I didn't make a nand backup of my rooted sense stock. Is there anyway to do it now?
Two questions.
1. Ive had this problem from beginning cm7. Nobody seems to know a fix. At least none posted here. I use Google voice and ignore voicemail notification. Ever since 2.3.3 I notice it less often. I think.
2. Try Sprint Lovers rom. Its based off sense stock.
720p Video Recording
Does anyone know if 720p video recording is possible or planned for CM7? It looks like the max resolution supported right now is 480p (720x480). Under a stock Sense ROM 720p (1280x720) was possible.
Are they any themes for the lock screen? I know it has more build in but I'm just wondering.
I use this Honeycomb style lockscreen from my homie Bizdady
http://forum.xda-developers.com/showthread.php?t=959602
+1 on the honeycomb lockscreen, its pretty slick.
I told him careful if he posted it in the general android themes section. I knew he was going to be flooded with requests. I would txt him and ask him what was he doing. His reply was making/updating zip files lol
Think CM will ever incorporate a push button way of updating the PRL like how its done in sense? Only options now are to flash to sense rom and update it, or people are making flashable zips of the updates now-a-days right? Just a random though.. thought i'd ask :)
Anyone know a link to a honeycomb theme for the cm7 nightlys? Im on 12
Sent from my PC36100 using Tapatalk
every time i change to a theme that has a blue battery it stays green -_- like on the honeycomb theme it doesnt stay blue. same with honeycream -___-
noroldie
