[Official] CyanogenMod 7 discussion
Is it just me or did the icon for the music app change? I've been using the honeycomb music player for a while so I haven't paid much attention to the original version lately.. Maybe the music player jas some new additions?
All you found was 2 things?
Sheesh man, its not like you paid to use the rom or anything besides, imagine the coding it took to make it.
Well, welcome back. You're alive. I was just bored. Thought I stir up things alittle and I do appreciate this great rom the best out there and all the hard work by the CM team so with that being said, can you tell me what the video quality setting is for High Low and two other?
My experience i use certain widgets on cm7 and after a while my phone resets and i cant use those widgets anymore..... For example circle battery widget and battery widgets in general ...why how do i fix that .
I too noticed the new camera/video options, but it appears that 720p (1280x720) support is not there yet. Just tested recording a short video on "High" and it was 480p (720x480).
Thanks for testing.
Can anyone confirm Wi Fi working? I'm down in a hole and can't get Wi Fi but it may very well be a signal issue...
voicemail on cm7
I can't seem to figure our how to retrieve my voicemails. If I dial "1" it gives me a weird message.
Okay so I just flashed CM7 #11 Everything went fine. I had to call Sprint so I used the *2 it connected was able to use dialpad for prompts etc. Then while the tech had me on hold the screen blanked out and nothing I did brought it back I couldn't retrieve the dial pad the the menu buttons didn't work or the top button but my call was still connected when I finished my call the screen was still black buttons still didn't work and I had to pull the battery in order to restart my phone. Anyone else experience this or know what may have caused it?
Sounds like a glitch in the screen being shut off by the proximity sensor... I've had similar problems with CM6 in the past but not recently.
Ok.. after a day's use I have to say #13 is the best build I've used since #1 b4 the RC.
Sent from my EVO 4G using Tapatalk Pro
I was scared to try 13 wasn't sure how stable it would be I'm a have to check the change log to see whats new. Then I may go for it!
jenleasch12683
