[Official] CyanogenMod 7 discussion
Any chance teamwin's 'hdmi out' is in here? I'm guessing not. Going to flash in a bit regardless.
I just flashed it from nightly 8 and once it boots, it tells me that my sd card is broken. It won't mount and I an't access it. When I take the card out and plug it in to my pc, it works perfectly. Not sure what is causing this. I did a cache/dalvik wipe, but I did not do a factory reset. Weird...
I'm able to get to my SD card with no problems.... You may need to do a cache / Dalvik cache wipe and maybe even a data wipe...
Is anyone else having wi fi issues or is it just me again??
I just did a data wipe as well, still tells me the sd card is broken. I just restored back to 8 and the sd card is fine again.
Updated to RC2, and was having a wifi error. Restarted, it worked, getting errors again.
Also, can't get Wireless Tether for Root users to work. Any ideas?
Well I was going to update to the RC2 but looks like a lot of people are having trouble. I need my wifi to work. I use it all the time as I have it at work and at home. RC1 gave me the same problems with wifi as being reported about RC2. Looks like the RC's are not as good as the nightly builds as I have better luck with them.
I'll just keep following to what else isn't working :-\
Same here....Im going to stick with the nightly builds until the final version. nightly build #13 is working great for me.
Nice to see progress.. I'm going to stay on nightlies.. has anyone heard or know of this new music app feature that's been ported from the Xoom to the Evo4g? It lets you stream your music and stuff. I can't find the .APK
Sent from my EVO 4G using Tapatalk Pro
shawnjosecrespo
