[Official] CyanogenMod 7 discussion
Okay so my new problem but not so big problem is i downloaded the game backbreaker and for some reason on CM7 it wont load the game but on Kings UNleashed it lets me play can someone explain why this is happening?
Might not be supported by gingerbread? Try reinstalling it and rebooting i guess.
GPS is still not working in CM7...but there's now a workaround that apparently solves the problem. Many people are reporting sucess; I just applied the workaround and gps is finally working for me on CM 7 #18.
You need to flash a Sense ROM, then use a ## code to do a total wipe on the GPS hardware (these codes are only available on a ROM derived from the official Sprint one).
When you enter the code, you'll be prompted to enter your MSL number, so make sure you have that before starting (there's an app in the market called MSL reader that'll get it for you).
Afterwards, you can go back to CM and the GPS works.
Details in this post on xda.
No, GPS still not working on CM7 nightly 18. I did everything exactly with no problems but after restore CM7 18 GPS did not work.
so I flashed CM7 on my fone and its stuck booting on with the screen with blue android and a arrow that keeps circling animation...what did I do wrong and how do i start over??
what do I need to wipe when I install CM7..managed to get back to recovery....I wiped Cache and dalvik...do I need to wipe the factory reset also??
If you're just updating from a previous CM7 version, you just need to wipe both caches. But if it's a whole new ROM, wipe both caches and data.
quick question im running nightly 18 if i upgrad to 19 and wipe cache and dalvik do i still need to do the gps fix again?
#19 is working fine, except the same bug where the Phone app comes up with Contacts instead of the dialer.
ok just tried the wi-fi tether app, and it is a no-go. Like I said though the built in wi-fi tether is working, That's good enough for me.
Tether works for me and now Navigation works. I have never done the sense fix. If you guys are still having issues you might want to fully wipe and do a fresh install.
Reactions: gksmithlcw
Yeah, I didn't do a full wipe with the upgrade to 19. I might have to go ahead and do that. Were you using the Wireless Tether app, or did you go through Settings and turn it on?
Been using build 13 for awhile now, guess I'll "upgrade" to 19 and give it a spin as soon as I backup 13 and finish downloading 19.
Ok...noob question again...what do I do for voicemails...is there a app I should be using since my sense voicemail app is gone.
rvrsco
