[OFFICIAL] GS3 JellyBean Discussion
Re: [OFFICIAL] GS3 JellyBean Speculation
think ill have to reset.. check out this Quadrant score since upgrading
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess ;)
Just ran quadrant and this is what i got.
Funky, let me know if the reset works. Dont fancy losing flash.
Thats what i got
Sent from my GT-I9300 using Tapatalk 2
Mervyn, did you do the reset
Yeh bro the lady i contacted at samsung said the full reset procedure is designed to remove all the old system files.. looks like its true with my quadrant score
follow that message i posted no interruptions should be fine
its somehow fixed itself
all i did was use that new JB function to remove app icons from statusbar :confused:
glad i didnt reset lol. might still do a reset soon once im rooted and backed up. might even give CM10 a try ;)
you can sideload flash again so dont worry about that. i also did a soft reset (hold in power button until phone shuts down).
if youre usin a dual core s3 the score will be lower than ours but should be in the 4000s. clear ram and notification before testing and switch wifi off until the test is done
@Mervin, do sport cards work on google Now in UK mate?
ive told it my team is Celtic, theyre playin now but Now has told me nuthin :(
I got nothing for my team either... and if I ask for scores it does a when search instead of bringing up a score card...
Maybe an EPL supporter would have better luck (my team is in the championship)
lol i added Man City just to piss Mervin off and test if i get cards for them :)
What's the latest rumor on AT&T getting Jelly bean for the S3? I just bought it, arrivign Thurs or Fri. I'm wondering if I should bother learning how to root or just wait for JB.
How did you do that??
*sigh* 4.1 isn't even out for the S3 U.S. and some of the 4.2 features are already announced. What the heck.
While I agree, I doubt Samsung or any other OEM would add them anyway, outside of the enhancements to Google Now. We'll never see the panorama, or any of the camera features, and I seriously doubt we'll ever see the native JB keyboard come standard on a Samsung device either. The $350 price tag has me seriously considering buying a Nexus 4 but no LTE, and expandable memory has me thinking twice.
its a new function in jellybean mate.
in app info you can uncheck "notifications"
handy for those annoying air-push ads :)
My OTA arrived today. Seemed to go OK. I just let it happen. Phone seems much the same as before (but with new features I still have to play with).
Baseband version is I9300XXDLID
Android is 4.1.1
Kernel is 3.0.31-368423 - 19th Oct 18:17:48 KST
Build number is JRO0C.I9300XXDLJ4
cheers
Alan
What's the professional way to reset the Galaxy S3 after update? Can I just back up my data with the Samsung Kies and after resetting just upload them back to my Galaxy S3? Or how reset is done without losing any important content of the phone?
Thanks in advance!
Thanks in advance!
And I would recommend a factory reset after installing any new version of Android. You can download all your apps after reset from GooglePlay and you can use the data backup for the personal info such as contacts and calender(or you can you Google online backup for those as well)
Thanks in advance!
you have to root and use a backup app to save app data/settings mate
I haven't bothered with all that. I just carried on using it.
okay.. i did the OTA update yesterday once again, the installation stopped at 24%(once again) with an exclamation mark. so basicly it downloads, then the installation stops at 24%. seriously what should I do here?
roksakure
