Ok, Lets Get to the Root of the Mic Cutout Problem
My guess is that it's probably a hardware issue that is triggered under certain conditions, similar to the volume bug on the GSM version. Like that issue, may be there is a sofware fix.
INFO:
Frequency of dropouts (estimation): 2-3 times a week sometimes twice in a day
Your physical location (preferably locations you have noticed the mic to have dropped out) City, State preferred: Wilmington, NC
First 12 Digits of Serial Number: 014697580200
Screenshot of "About Phone" list under settings OR
-Android Version: 4.0.2
-Baseband Version: I515.09 V.EK05 / I515.EK02
-Kernel Version: 3.08-gaaa2611 android-build@apa28 #1
-Build Number: ICL53F
Type of data connection set at the time of mic drop out (all that apply) [LTE or CDMA mode/ CDMA only mode/WiFi]: LTE
Were you using the Speaker Phone? (yes/no/both): NO
Do you use any type of Voice over IP apps or video chatting apps (Skype, google talk, etc...)?: na
- Which ones?: none
- Mic Cut outs during those calls?: na
Is your phone encrypted?: no
Sim Card Lock enabled?: uk
Anything Enabled in "Developer Options"?: usb debug enabled
-If so, what?:
Have you tried a factory reset?: yes
Have you tried using the phone with nothing but the original apps that came with the phone installed?:
if yes, were you still getting cut-outs?: yes / yes
Bootloader Unlocked?: does this on both unlocked and locked
Rooted?: doesnt matter does on both
Tried different ROM's?: yes
- Which ones?: p3droid and stock
And the one that I'm sure no one is going to answer but in case you feel a desire to share:
Post screenshots showing all of the apps in your app drawer:
n/a
Hello,
I am Akshay frm India. I have problem regarding the mic after i rooted my phone..... It is not at all working after i did the following:
1) Unrooted it
2) Used other dialers(external applications)
3) Installed audio managers
4) Factory formatted many times
5) Changed microphones(hardware component)
6) Asked suggestion many times to professionals but i didnt get the answer for anything.....
*The good thing is that my microphone works when i am recording i.e. by camera(default app for video recording), sound recorder(default app for sound recording) i get the voice after i preview them.
* My earphone microphone works fine always
* There is no dropping of mic of earphone during the call.
* There is no dropping of mic during recording time but when i play the recorded video or audio in computer or earphones, the audio plays in only one of the earphone or speaker i.e. it has recorded in mono not stereo.
I hope u will provide me the best and working answer.
Thank you.
inglewoodpete
