On my Samsung Note 3 n9005, why doesn't LTE work?
gayanlk3
I have a samsung note3 n9005 lte does't work.
I got this from singapore. Now I'm in sri lanka.Anroid version is kitkat 4.4.2. Just want to know that wll 4g work if I install kitkat 4.4.4? Or will I have to do full software update. Please answer this question. I'm totaly frustated.
Thanks
Re: I have a samsung note3 n9005 lte does't work.
Welcome to Android Central! LTE reception depends on the network bands the carrier uses and which ones the phone's hardware are compatible with. If they're not compatible, then no software update will make them compatible. You would need to find out which bands your carrier uses, and see if they correspond to the LTE bands that your phone uses: Samsung Galaxy Note 3 N9005 LTE - Specifications
osirisgothra
